Next-Level
Next-Level
Suction Power
22,000Pa
HyperForce® Suction Power6
Hair Removal Rate on Carpet7
Saros 10
Saros 10
Down To The Finest Detail
Available in Two Options
Saros 10
Manual Water Replacement
Flexible Base Station Placement
Automated Water Replacement
Pre-Check for Installation Required
The Thinnest Roborock
to Make a Big Difference
7.98 cm
Ultra-Thin Design
Ultra-Thin Design
The RetractSense™ Navigation System lowers its LDS to pass under low-clearance areas and rises again in open spaces, all while featuring Roborock's slimmest design yet.1
Meticulous LiDAR,
Meticulous LiDAR,
More Than Simply
Rising and Retracting
AdaptiLift™ Chassis
AdaptiLift™ Chassis
Overcome Barriers,
Expand Possibilities
Up to
1.57 inches
Threshold Clearance2
With a clearance of up to 1.57 inches (4cm)—featuring the industry-first AdaptiLift™ Chassis3 —Saros 10 effortlessly crosses doorways, managing 1.18 inches (3cm) thresholds with an additional 0.39 inches (1cm) track for double-layer thresholds, or up to 1.18 inches (3cm) for single-layer thresholds, ensuring uninterrupted cleanliness.
Prevent Getting Stuck
AdaptiLift™ Chassis adapts to different obstacles. Saros 10 automatically optimizes the best obstacle-crossing strategy by lifting its omni wheels and drive wheels, ensuring smooth, uninterrupted cleaning even in challenging situations.
Saros 10 elevates the chassis up to 0.39 inches (10mm) on high-pile carpets, reducing suction port blockages from long fibers.4
Hair Tangling?
Divide and Conquer
Divide and Conquer
Hair Tangling5
DuoDivide™ Main Brush
The DuoDivide™ Anti-Tangle Brush transports collected hair to the dustbin inlet in the center, where the hair is stripped off and powerfully suctioned into the dustbin.
Learn More About How the Dual Anti-Tangle System Works
Hair Tangling5
FlexiArm™ Riser Side Brush
VibraRise™ 4.0 Mopping System
Enhanced, in Pretty
Much Every Way
Mop, Unclip!
Larger, Harder, Smarter
The VibraRise™ 4.0 Mopping System features a denser, more absorbent mop that locks in moisture for effective stain removal. Dual sonic vibrating zones at 4,000 times/min each, up to 8N pressure, and a 26% larger vibration area ensures superior mopping performance.9
26% Larger
Mop Vibrating Area10
Up to 8N
Up to
8N
Downward Mopping Pressure11
Up to 220 RPM
Up to
220 RPM
Side Mop Speed12
Side Mop Independent Lifting
Edge-to-Edge
Edge-to-Edge
Coverage
Edge and Corner Sweeping14
0.002 inches
Edge-Close Mopping14
Adaptive Elevation
Adaptive Elevation
for Spills and Carpets
For Spills15
For Carpets
Mop Removal For Carpets
For Spills15
  • Side Brush Lifts
  • Main Brush Lifts
  • Mop Lowers
  • Vacuum Motor Stops
For Carpets
  • Side Brush Lifts
  • Main Brush Lowers
  • Mop Lifts4
  • Vibrating Mop Removed
  • Main Brush Lowers
  • Side Brush Lifts
Quadruple, Exceptional
Saros 10 features an advanced perception system with front triple structured light, an RGB camera, and VertiBeam™ lateral structured light. It offers a wider obstacle-avoidance view, minimal blind spots, and clear detection near and far with swift response.
Dodge Fast
Clean Close
VertiBeam™ lateral obstacle avoidance precisely measures the distance between the robot and side obstacles, ensuring accurate edge cleaning along furniture and objects.
RockDock® Ultra 2.0
RockDock® Ultra 2.0
Clean Deeper, Charge Faster
The RockDock® Ultra 2.0 blends sleek design with practical convenience. It features an AG-treated tempered float glass lid that opens with a simple press, while the dust cover on the water tanks ensures lasting cleanliness.
This is a image 176°F Dynamic Mop Washing16
This is a image Auto Mop Detaching
This is a image 140°F Heated Air Drying17
This is a image 150-Min Fast Charging19
This is a image 176°F Dock Self-Cleaning16
This is a image Warm Water Tank Refilling
The RockDock® Ultra 2.0 uses adaptive water temperatures to tackle stains, preventing starch-based stickiness, melting oil stains, and sterilizing at high temperatures to remove 99.99% of Staphylococcus aureus and Escherichia coli from the mop after self-cleaning.18
122°F
140°F
176°F
For stubborn grease stains.16
122°F
140°F
176°F
RockDock® Ultra 2.0 fully powers a 6400mAh battery in just 150 minutes. The dock intelligently adjusts the charge needed based on the remaining area, so you don't need to wait until it's fully charged.19
Saros 10 is also available with a refill and drainage system, eliminating the hassle of manually refilling and emptying water.
The Quietest
The Quietest
Roborock Yet
52 dB(A)
Quiet Mopping Mode21
72 dB(A)
Dock Self-Emptying21
Explore the Roborock App and Its Pet-Friendly Features
Easy-to-Use App
Tap, Tap, Clean
Roborock SmartPlan™ 2.0
Saros 10 intelligently identifies floor types and room categories, and customizes the optimal cleaning strategy based on each area and past cleaning habits.
No Internet?
No Internet?
No Worries, It Still Works
Cereal Spilled
Busy Working
Finished Cooking
"Hello Rocky, clean here."
Cereal Spilled
Busy Working
Finished Cooking
As Always
As Always
Pick It Up
Gather It In
Strip It Off
Suck It In
Asymmetrical Spiral Arc
Soft Rubber Baffle
Longer Side Brush Bristles
& Drainage System
Auto Water Refill and Drain
Check Your Environment
Space Requirements
Clean Water Inlet
Power Plug
Dirty Water Outlet
More than 3.3 ft (100cm)
More than 1.4 ft (42cm)
More than 1.0 ft (30.5cm)
Strong Wi-Fi Coverage
Installation Requirements
1. Reserve a space of at least: 1.0 ft (30.5cm) in height, 1.4 ft (42cm) in width, and 3.3 ft (100cm) in depth.
4. The height difference at any point on the drainage pipeline from the ground is recommended not to exceed 1.6 ft (50cm).
5. The installation distance for the water refill and outlet pipes is recommended within 19.7 ft (6 meters). If not, please contact customer service for consultation.
6. The water pressure range is 14.5-58 PSI (0.1-0.4 MPa). If it exceeds 58 PSI (0.4 MPa), please use a pressure-reducing valve.
8. Ensure there are no thresholds, tracks, or steps higher than 0.79 inches (2cm) between the dock's installation site and the cleaning area to avoid the risk of getting stuck or missing cleaning.
Compact Design
Seamlessly fits in your home environment and saves space with an impressive dock height of just 0.98 ft (30cm).
Your This is a image Furry Friends
Deserve the Best
Video Call
Other Thoughtful Features
Up to
30
Partitions Supported
Automatic Map Correction
Up to
30
Saros 10
Robot (LDS Retracted)
13.78 x 13.90 x 3.14 inches
(350 x 353 x 79.8 mm)
Robot (LDS Elevated)
13.78 x 13.90 x 3.68 inches
(350 x 353 x 93.5 mm)
16.10 x 17.32 x 18.50 inches
(409 x 440 x 470 mm)
16.10 x 17.32 x 11.81 inches
(409 x 440 x 300 mm)
  • Custom Cleaning Routines
  • Child Lock
  • Sensient® Sensor Array
  • Quiet Mopping
Product Comparison
2. Based on Roborock internal testing. This product is tested to cross thresholds up to 1.57 inches (4cm), including a 1.18 inches (3cm) threshold plus an additional 0.39 inches (1cm) track on top for double-layer thresholds, or up to 1.18 inches (3cm) for single-layer thresholds. Actual results may vary depending on usage conditions.
