Roborock F25 ACE Pro
Foam Up, Stains Down.
Buy Now
JetFoaming™ Cleaning
167 million¹ ultra-dense bubbles dissolve stains and odors².
JawScrapers® Anti-Tangle Structure
No need to manually remove hair from the roller.
25,000 Pa Suction Power³
Powerful suction reaches and removes hidden dirt.
FlatReach® 2.0 Lay-Flat Cleaning
180° full-flat design for under-furniture cleaning.
SlideTech 2.0 Smooth Steering
Intelligent assist for effortless push-pull.
Smart Self-Cleaning and Drying
Adapts to dirt level for thorough, one-time cleaning.
35% Larger Water Tank⁴
Fewer refills for longer, uninterrupted cleaning.
App and Voice Alerts
Stay informed with real-time status updates and reminders.
Tough Stains and Smells²
- All Covered
JetFoaming™:
Spray, Sweep, Stains Gone.
JetFoaming™: Spray, Sweep, Stains Gone.
Introducing Roborock’s revolutionary foam cleaner, featuring an ultra-dense foam system that transforms just 1 ml of Foam Cleaning Solution into 167 million¹ microbubbles—designed to cling to, dissolve, and lift even the toughest stains.
Handles Whatever Life Spills.
Kitchen Mess
Greasy steak drippings, pasta sauce, and splashes of cooking oil.
Bathroom Stains
Toilet-edge odor stains, toothpaste residue, and stray hairs.
Dining Area
Soup spills, baby food smears, and sticky messes.
Pet Zone
Wet pet food, canned pet soup, paw prints, and the occasional pet urine accident.⁵
Clean Beyond What You See.
Experience deep cleaning that reaches from visible messes to hidden dirt. TÜV-certified results show our cleaning system captures stains and germs, removing 100%⁶ of visible messes and over 99.9999%⁷ of invisible bacteria.
Instant Foam Power, Spot-On Clean.
Instant Foam Power,
Spot-On Clean.
3 simple steps to a faster, deeper clean—powered by JetFoaming™ technology
  • On-Trigger Foam Prep
    Press and hold the trigger to activate the system — air and solution are precisely blended, generating dense foam through the front nozzle within seconds.
  • Even Spray
    High-density foam spreads in a uniform layer, fully covering stains to stop smearing before it starts.
  • Dirt Break-Down
    Active foam and cleaning solution work together to scrub and lift stains, delivering a deeper clean.
Gentle on Your Home,
Safe for Your Family.
TÜV-certified for slip resistance⁸ and zero floor damage⁹, helping keep your floors pristine and safe.
Our Foam Cleaning Solution is tough on dirt but safe for families and pets¹⁰. With zero harmful additives¹¹, it neutralizes common household odors¹², keeping your home fresh and worry-free.
Formaldehyde
Alcohol
Bleach
Methanol
Oxidant
Scrape, Sweep, and Stay Tangle-Free.
Scrape, Sweep,
Scrape, Sweep,
The JawScrapers® design combines shark-tooth blades with constant-pressure scrapers to capture hair early, keeping rollers hair-free and floors spotless and free of watermarks.¹³
  • 2000 Strands
    50 cm long hair
  • ≥ 90%
    Pet Hair Removal Rate¹⁴
  • 0%
    Tangle Rate¹⁵
Smarter Cleaning,
Deeper Results.
During cleaning, the system auto-detects dirt levels and adjusts suction and water flow accordingly*. It deep-cleans tough spots and quickly refreshes lighter ones — saving time, effort, and repeat passes.
Cleaning Level
4 ...
Dirt Level
*Available only in AUTO and Sponge modes
With 25,000 Pa suction, 30 N downward pressure, and 430 RPM brush rotation, it lifts embedded dust and tackles wet and dry messes for a deeper clean.
  • 25,000 Pa
    Suction Power³
  • 30N
    Downward Pressure¹⁶
  • 430 RPM
    Cleaning Strokes/min¹⁷
Cleans Every Edge, Every Time
Edge-to-Edge Cleaning,
Zero Missed Spots.
Dust tends to accumulate along walls and corners. With edge-to-edge coverage on three sides—front, left, and right—the roller achieves true 0 mm edge cleaning¹⁸, keeping every corner spotless.
Clean Low Areas with Ease.
The body tilts smoothly to a full 180°, maintaining suction even when completely flat.
At just 12.5 cm (4.9 in) high¹⁹, it easily glides under furniture such as beds and sofas.
Smooth in Motion, Easy in Use.
Power That Moves with You.
Driven by dual brushless motors with FOC vector control, SlideTech 2.0 detects motion in real-time and auto-adjusts assistive force every 100 ms for effortless, balanced push-and-pull.
70° Swivel Design²⁰
Turns That Move with Your Flow.
With independently controlled dual wheels, SlideTech 2.0 adjusts each wheel’s speed precisely for smooth, balanced turns—letting you glide effortlessly around furniture with quiet stability.
Sit Back, Stay in Control.
With remote control mode²¹, you can steer the cleaner directly from the Roborock App—perfect for quick spills and hard-to-reach spots. Convenience at your fingertips.
Auto Detergent Dispenser
Separate detergent and water tanks automatically mix the optimal solution for each clean, while the Roborock App lets you adjust detergent levels for personalized, waste-free cleaning.
Just Leave the Dirty Work to Itself.
to Itself.
Intelligent High-Temperature Self-Cleaning
Clean at 95 °C for Deep Hygiene.
During self-cleaning, high-temperature washing can break down grease and residue while inhibiting bacteria — leaving the roller deeply cleaned and odor-free.²²
>99.99%
Bacterial Removal Rate²³
Proactive Self-Washing²⁴
Self-Cleaning That Adjusts Itself.
As you clean, the system automatically optimizes rinsing for better results by DirTect® Smart Sensor.* Once docked, it self-cleans with alternating brush rotation to remove residue and refresh bristles for a deeper clean.
*The smart sensor detects dirt levels in real-time, automatically adjusting for optimal cleaning intensity across surfaces as it cleans.
High-Temperature Self-Drying
High-Temperature
Self-Drying
Always High-Temp,
Always Dry
With 95 °C airflow²⁵, hot air reaches the brush core for fast, thorough drying. The sealed dock locks in heat to prevent moisture, mold, and odors — keeping the roller fresh for next use.
99%
Full-Cycle Drying Rate²⁶
5-Minute Fast Drying
—Ready When You Are
Equipped with 18 hot-air outlets and a 360° bi-directional airflow system, the Roborock F25 ACE Pro delivers complete, all-around drying—from the roller and dock to the air duct, cover plate, and even the sewage pipe and filter.
Quiet Drying, Peaceful Nights
Lower airflow and brush speed keep drying gentle and quiet — completing a 30-minute cycle at just 48 dB²⁷, so your nights stay calm while it prepares for the next clean.
Always High-Temp, Always Dry
99%
5-Minute Fast Drying—Ready When You Are
Your Home, Cleaned in One Go
Your Home,
Cleaned in One Go
Experience Uninterrupted Cleaning
Up to 60
min. using²⁸
Under Eco Mode
1,000 ml²⁹
35% Larger Clean Water Tank
Handles the Mess,
So You Don't Have to
Adjusted Just the Way You Like
Adjusted Just
the Way You Like
Stay Informed,
No Missed Alerts.
Get reminders when filters or rollers need cleaning or when tanks need refilling.
Personalize the
Cleaning Settings
Customize every detail to suit your home and lifestyle.
Timed Self-Cleaning & Drying
Clean and dry on your schedule - without disrupting work or rest.
Key Specs
Wet & Dry Vacuum Cleaner
265×250×1100 mm
Vacuum Cleaner with Dock
316×353×1165 mm
2. Based on internal testing carried out by the manufacturer. Stains refer to common household messes such as grease, sauces, coffee. Odors refer to Ammonia,Trimethylamine, and Hydrogen sulfide.
3. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards. Actual results may vary depending on environmental factors.
4. Compared with the Roborock F25 ACE, which is equipped with a 740 ml water tank.
5. Certification No. Z2GCN 118006 0168 Rev. 00 by TÜV SÜD, based on testing on floor pet stain cleaning efficiency, pet food, canned pet soup, soil and dirt mixture, simulated pet urine are effectively removed.
7. Certification No. Z2GCN 118006 0168 Rev. 00 by TÜV SÜD, based on testing on Max mode, over 99.9999% bacterial of Pasteurella multocida, Microsporum canis on the floor are effectively removed.
8. Certified No.704012506561-00 by TÜV SÜD, based on testing on after cleaning by 10s Spray Foam +3x Reciprocal Push-Pull Cleaning Push-Pull Cleaning in Power Mode, the average static coefficient of friction of the test tiles is greater than the test tiles before cleaning.
9. Certified No.704012506560-00 by TÜV SÜD, based on testing on solid wood flooring to push and pull for 18,000 times in 60 minutes. The floor did not occur blistering, bulging, deformation phenomenon and no obvious scratches and color difference. Actual results may vary depending on environmental factors.
10. Considering the toxicological data and actual use of the final product, safety concerns are not expected to occur under normal and foreseeable conditions of use.
11. Refers to the absence of intentional addition of the following ten ingredients during production: formaldehyde, alcohol, sulfates, phosphates, oxidants, bleach, fluorescent brighteners, parabens, formaldehyde-releasing preservatives, and methanol.
12. Certified No. 7216006414-1 / 2 / 3 by TÜV SÜD, based on odor-removal tests using 500 ml ammonia, 100 ml hydrogen sulfide, and trimethylamine under 24-hour air purification conditions. results may vary with environmental conditions.
14. Certification No. Z2GCN 118006 0168 Rev. 00 by TÜV SÜD, based on testing on default cleaning mode, over 90% pet hair on hard surface can be effectively removed. Actual results may vary depending on environmental factors.
15. Data sourced from SGS and Roborock's internal testing. In the SGS testing environment, the hair tangling rate of the floor washer was 0% across all four operation modes.
16. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
18. Based on internal tests conducted by the manufacturer using dust. Edge cleaning performance reached 0 mm in these tests. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
20. Based on internal testing by the manufacturer. 70° steering refers to the combined rotation of both brush heads, each turning at least 35°. Actual performance may vary by environment.
21. Remote control works only when the device is laid flat at 180°. App connection required.
22. Based on internal testing by the manufacturer. The stated 95°C refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual performance may vary depending on environmental conditions.
23. Certification No. Z2GCN 118006 0064 Rev. 01 by TÜV SÜD, based on testing on Max mode, over 99.99% bacterial of Staphylococcus aureus, Escherichia coli, Candida albicans and Klebsiella pneumoniaeon on the floor are effectively removed.
24. Proactive self-washing is available on the Roborock F25 and Roborock F25 ACE models. The rest of the F25 series are equipped with a default self-cleaning mode that activates after docking.
25. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
26. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
27. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
28. Based on internal testing carried out by the manufacturer under Eco Mode. Actual results may vary depending on environmental factors.
29. Based on internal testing carried out by the manufacturer. Compared with the Roborock F25 ACE, which is equipped with a 740 ml water tank. Actual results may vary depending on environmental factors.
