| Vacuum-only | Mop-only | Carpet cleaning | Returning to dock | Mop drying | |
| Mops Lifted |
low-pile carpet
| Mops & Chassis Lifted |
mid-to-long-pile carpet
| Brush Lifted |
| Mops Lifted | Mops & Chassis Lifted | Brush Lifted | |
| Vacuum-only |
| Mop-only |
| Carpet cleaning |
low-pile carpet
| Returning to dock |
| Mop drying |
Carpet Boost+ System®
Customizable App Features
Sensient™ Sensor Array
Adaptive Route Algorithms
Child Lock
Off-Peak Charging
352 * 347 * 103 mm
340 * 487 * 521 mm
1. Certified No.PT/24/GEN/0244/1 by SGS. Actual results may vary according to the home environment.
2. Certified No.PT/24/GEN/0243/1 by SGS. Actual results may vary according to the home environment.
3. Certified No.PT/24/GEN/0245/1 by SGS. Actual results may vary according to the home environment.
8. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
9. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
12. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
13. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Test Report number:CN24N13I 001. Actual results may vary according to the home environment.
