Saros Z70
A Robotic Cleaner,
Now Also a Robotic Helper
Recognize and Organize Socks? Toward the closet. Sandals? Toward the entrance rug. Crumpled tissues? Toward the Store Box*. The Saros Z70 identifies and relocates household items to their designated spots, as programmed in its software. *App connection and setup are required for the obstacle management feature. Actual performance may vary due to software updates and environmental factors. *Current recognizable and organizable objects include socks, sandals, crumpled tissues, and towels under 300g. New items will be added continually via firmware OTA updates.
OmniGrip™
OmniGrip is equipped with precision sensors, a camera, and an LED light, enabling it to determine its position, surroundings, and the weight of each object it grips. This ensures the mechanical arm operates with exceptional accuracy.
AI-Powered Customization
In addition to the 108 objects1 pre-programmed into the robotic vacuum, the Saros Z70 utilizes customizable AI-driven recognition technology, empowering users to define and label up to 50 new objects2 in the app for personalized interaction and enhanced functionality. *
Safety and Privacy Powerful Yet Gentle The OmniGrip arm features a gentle-grip design, capable of securely holding objects without damage. A built-in weight sensor prevents it from lifting items over a safe threshold (300g3). For added convenience, the grip can be manually reversed to release objects effortlessly when needed. This thoughtful design balances strength and care, providing a secure hold while preventing excessive squeezing.
Customize as You Need OmniGrip features are disabled by default and can be activated by users based on their specific needs.
Engineering Marvel
Roborock's Slimmest,
Most Compact Design Yet
7.98cm Ultra-Slim Design
All the pioneering cleaning features of Roborock vacuums are present in the Saros Z70, along with its groundbreaking mechanical arm that delivers an unprecedented experience. Integrating these advanced features into Roborock’s slimmest-ever 7.98 cm4 design — with a mechanical arm occupying 10%5 of the space of previous models — required rigorous R&D and innovative engineering.
Still the Reliable,
All-Round Pioneer.
VertiBeam™ Lateral Obstacle Avoidance Improved accuracy in recognizing unfolded cables and irregular walls & furniture.
Navigation System 21 x Improved Sampling Frequency than LDS6
Obstacle Recognition 108 types of Obstacles Recognizable7
Dual Anti-Tangle System
No Stuck, No Fuss
FreeFlow™ Main Brush
FlexiArm™ Riser Side Brush 0% Hair-tangling Rate8
22,000 Pa HyperForce®
S7 Max Ultra 5500 Pa
S8 MaxV Ultra 10000 Pa
Saros Z70
FlexiArm™ Riser Side Brush and Mop
Clean Closer, and Closer
The FlexiArm™ technology empowers double robotic arms for the side brush and the mop to expertly sweep dirt from corners, edges, and under furniture. It ensures complete cleaning coverage, leaving no blind spots behind for a truly thorough home clean.
100% Edge and Corner Coverage10
0mm Along the Edge and Corner11
FlexiArm™ Riser Mop
Industry-first AdaptiLift™ Chassis12
Built For Versatile Lifting
4 cm Maximum Double-Layer Thresholds Crossing13
Mid-to-High-Pile Carpet
U-Shaped Furniture Leg
4 x Liftable Designs
- 22 mm14 Maximum Mop Lifting
- 10 mm15 Chassis Lifting
Chassis Lifted
Multifunctional Dock 4.0
Auto Mop Removal
2.5-Hour Fast Charge
80℃ Hot Water Mop Washing
Smart Re-Wash & Re-Mop
Auto Detergent Dispenser
Warm Water Tank Refilling
55℃ Warm Air Drying
Detachable Dock Base
Auto Mop Removal
When Vacuum-Only
When Vacuum Carpet First
99.99% Bacteria Removal Rate
590ml Capacity
Next-Level Intelligence
Say “Hello Rocky” for Help
Easy-to-Use App
Tap. Tap. Clean.
Roborock SmartPlan™ 2.0 One Tap to
AI-Driven Cleaning
This is a image Enjoy truly automated cleaning with Roborock SmartPlan™ mode. All you need is a tap in the app, and the robot automatically adjusts its settings based on AI-analyzed environments and cleaning history. It boosts suction and water volume for areas that need extra attention, reduces power during do-not-disturb hours, and cleans its mops after tackling bathrooms and kitchens.
Pet-Friendly Intelligence
Paw-some Sidekick for Pets
Pet and Pet Area Recognition It stops its main brush and moves aside in advance when approaching your beloved pets to avoid frightening them. It will boost suction when cleaning around pet supplies for a thorough clean.17
Broadly Compatible with
Product Dimensions
Saros Z70
13.78 x 13.9 x 3.14 inches
350 x 353 x 79.8 mm
15.0 x 18.7 x 19.21 inches
381 x 475 x 488 mm
4. As of January 2025, the Saros Z70 is the thinnest model among Roborock's vacuum robots.
