HyperForce® Suction Power 1
Uncompromised Excellence
10,000 Pa
HyperForce® Suction
Dual Anti-Tangle System
Auto Lifting Mopping
System
VibraRise™ 2.0 Mopping
System
ReactiveTech Obstacle
Avoidance
PreciSense® LiDAR
Navigation
Self-Emptying Dock
Flexible App Control
Available in 2 Options
Roborock Q10 PF
Roborock Q10 PF+
Impressive HyperForce® Suction Power
Root Out Hair From
Crevices and Carpets
Suction Power
Root Out Hair
From Crevices and Carpets
Fewer Tangle. Fewer Trouble.
Dual Anti-Tangle
Design
JawScrapers Comb
Anti-Tangle Main Brush
Hair Tangling on Side Brush 2
Removes Dust You
Hardly See
Auto-Lifting Mopping System
The Auto-Lifting Mopping System automatically adjusts to carpets, providing a thorough clean with ease. Enjoy efficient, effortless mopping for consistently spotless results.
8mm
Mopping Module Lifting3
Ready to Avoid
Troubles, Every
Time
Powered by structured light, this advanced system effortlessly detects and navigates around obstacles, even in cluttered rooms with items scattered across the floor.4
PreciSense® LiDAR Navigation
Learn, Navigate,
Remember
RockDock® Plus
Handles Dirty
Work for You
Experience hassle-free cleaning convenience with the RockDock® Plus. The large dust bag lets you clean for up to 7-10 weeks without emptying5, making it ideal for families with pets and reducing allergens.6
Tap, Tap, Clean
Temporary Cleaning
Temporary Cleaning
Auto Boost on Carpet
High-Intensity Mopping
Cleans Along Floor Direction
Robot Vacuum
Robot Vacuum
Support for Alexa and Google Home
5200mAh Battery Capacity
Customizable Cleaning Modes
Off-Peak Charging
2. Based on testing carried out by TÜV Rheinland. For anti-hair entanglement in different modes, the certification no. is CN251UKF 001. The pet hair anti-tangle rate is 0%, while short human hair (20 cm) anti-tangle rate is 0.063%. Actual results may vary depending on usage conditions.
4. Based on Roborock internal testing. Actual results may vary depending on usage conditions.
