Roborock F25 Series
Smart, Smooth, Stainless
Roborock F25 Series
Smart Wet-and-Dry Cleaning
Spotless with a Single Stroke
JawScrapers
Complete Clean
Stays Clean and Ready to Roll
Seamless and Upgraded
Maneuverability
Intelligent App and
Voice Alerts
Sticky, Even Hairy Mess?
Make It No Mess.
99.99 %2
Bacteria Removal Rate
99.99 %2
Spend less time cleaning and more time living. With 20,0001 Pa suction and a 450 RPM cleaning frequency, the Roborock F25 Series delivers spotless results in a single stroke.
Cleaning Strokes3 / min
20,000 Pa5
Suction Power
>20 N4
Downward Cleaning Pressure
<1mm
Edge-to-Edge Cleaning7
<1mm
60 min
Battery Life under Eco Mode
410 sqm(4,413 sqft)
Cleaning Area per Charge
JawScrapers Roller
Designed for Lasting Shine
Tangle Rate8
12.5cm 0°
Power through tight spaces with a 12.5 cm9 flat design that keeps full suction at 0°. Its ultra-low profile reaches every corner, leaving no dust behind.
DirTect® Smart Sensor
Smarter for Superior Cleaning
Cleaning Level
4 ...
Dirt Level
Auto Detergent Dispenser
Enjoy up to 30 days10 of cleaning with a single detergent refill, as the auto dispenser precisely releases detergent as needed. *
Proactive Self-Washing
As you clean, the F25 series uses the DirTect® module to detect the cleanliness level of the water, so it knows how much it should be self-cleaned, even before it is placed back in the dock. *
Moves as You Move
Enhanced with dual brushless motors for individual wheel's controls, SlideTech 2.0 provides ultra-smooth maneuverability with millisecond response times, making tight turns smooth, whether pushing or pulling. *
Small Tweak, Big Improvement
90 °C
5 min
Fast Drying
99.99 %11
Multiple Stages
Separation System
99.99 %11
Multiple Stages
Separation System
Intuitive to Use,
Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
Easily monitor the device's performance and settings with a clear screen display, allowing for quick status checks at a glance.
One-Touch App Customization*
0 0
8. Data sourced from SGS and Roborock's internal testing. In the SGS testing environment, the hair tangling rate of the floor washer was 0% across all four operation modes. In the Roborock internal testing environment, the hair tangling rate was also 0% when operating with 200 strands of 30cm dry and wet long hair. Actual results may vary depending on environmental factors.
10.Based on internal testing carried out by the manufacturer. After fully filling the cleaning solution tank, it can provide up to 30 days of usage without needing a refill, based on once-daily usage in a test environment. Actual usage may vary depending on environmental factors.
11.Based on testing carried out by TUV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the roller are effectively removed. Report number: 704012406928-00. Actual results may vary according to the home environment.
