Roborock Qrevo Series
Hot Water Mop Washing
Intelligent Dirt Detection
Intelligent Voice Assistant
Reactive AI Obstacle Recognition
7,000 Pa HyperForce™ Suction
Auto Brush and Mop Lifting
Reactive Tech Obstacle Avoidance
Auto Mop Lifting
Room Temp Water Mop Washing
5,500 Pa HyperForce™ Suction
Auto Mop Lifting
Roborock Qrevo Pro
Get Closer, Clean Deeper
Meet the Roborock Qrevo Pro, a revolutionary cleaning solution that adeptly avoids obstacles. Reaching every edge and vanquishing every speck with effortless navigation, you're guaranteed flawless floors, only made better with dynamic hot water re-washing and re-mopping. Take control with the app, and get closer to your perfect cleaning experience.
View video
Flawless Cleaning Reach
98.8%
Edge Coverage
1.85 mm
Along the Edge
FlexiArm Design™ mop eliminates blind spots for an effective clean. It helps achieve flawless corners and edges effortlessly as the robot extends its mop, ensuring a 98.8% edge coverage with a precision margin of 1.85mm.1
Cleaning along the walls
Cleaning near the dock
HyperForce™ Cleaning Power
No Dirt or Dust Left Behind
Harness the unstoppable 7000 Pa HyperForce™ suction power, combined with an all-rubber brush and dual spinning mops, to effortlessly remove debris, dirt, and stains from various floor types, leaving you with spotless floors.
7,000 Pa
Extreme Suction2
All-Rubber
Main Brush
30 Levels
Water Flow Options
200 RPM
Spinning Speed3
Floor Cleaning Customization
Supercharged
Cleaning Performance
For Carpets
Achieve deep cleaning without wetting the carpet thanks to the handy 10mm mop lifting.
Vacuum Carpet First
10 mm
Mop Lifting4
Deep Carpet Cleaning
For Carpets
For Hardwood Floors
Roborock Qrevo Pro vacuums the floor along its direction so that the floor seams can be cleaned while minimizing scraping against them.
* The carpet and floor cleaning settings need to be activated manually in the Roborock app.
Multifunctional Dock 2.0
Auto Tank Refilling
Warm Air Drying
Auto Tank Refilling
Warm Air Drying
Roborock Qrevo Pro with Refill and Drainage System
On top of the maintenance-free dock features of the Roborock Qrevo Pro, we've introduced a refill and drainage variant, taking your hands-free cleaning even further.
Auto Water Refill and Drain
Check Your Environment
Strong Wi-Fi coverage
Installation Requirements
Auto Detergent Dispenser
550 ml
Detergent Tank Size
Compact Design
60℃ hot water effectively removes stubborn stains and other dirt, saving time and water, while also disinfecting, to ensure that the mops are clean for an improved mopping experience.
60℃
Hot Water
99.7%
Bacteria Removal Rate5
Re-Wash
Re-Mop
Warm Air Drying
Dries the mops and dock base completely with 45℃ of warm air, preventing the growth of mold and unpleasant odors.
Auto Tank Refilling
Detachable Base
Temporary Cleaning
Allows the robot to promptly deal with unexpected spills or messes without disrupting the regular cleaning routine. Alternatively, enables it to temporarily skip cleaning specific areas where necessary.
Fast Cleaning
Custom Cleaning Routines
Cleaning Access,
Always Within Reach
Third-Party Voice Control
Launcher Widgets
Apple Watch App
Elevate Your Clean with Adept Maneuvers
Detects and avoids potential hazards easily, so you don't have to pick them up off the floor before starting a cleanup. By suggesting No-Go Zones for stairs and easy-to-get-stuck places, the Roborock Qrevo Pro can prevent mishaps, allowing you peace of mind while it navigates your home.
PreciSense™ LiDAR Navigation
Precise Routes for
Precise Cleaning
6x Faster
Quick Mapping7
3D
Map Display
Multi-level
Mapping System8
Roborock Qrevo Pro
350 * 353 * 96.5 mm
340 * 487 * 521 mm
  • Customizable App Features
  • Sensient™ Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Roborock Qrevo MaxV
  • FlexiArm Design™ Edge Mopping System
  • Hot Water Mop Washing
  • Intelligent Dirt Detection
  • Intelligent Voice Assistant
  • Reactive AI Obstacle Recognition
  • 7,000 Pa HyperForce™ Suction
  • Auto Brush and Mop Lifting
Roborock Qrevo Pro
  • Auto Mop Lifting
Roborock Qrevo
  • Room Temp Water Mop Washing
  • 5,500 Pa HyperForce™ Suction
  • Auto Mop Lifting
7. Compared to Clean&Mapping mode. Actual results may vary according to the home environment.
8. Up to four floors supported.
**During a transitional period, Roborock Qrevo Pro may be depicted as Roborock Q Revo Pro in certain channels.
