Roborock Qrevo 2 Pro
A Power Leap.
Everyday Easy.
Buy now
A Power Leap. Everyday Easy.
A Power Leap.
Everyday Easy.
Designed for homes with carpets, pet hair, and everyday mess, the Roborock Qrevo 2 Pro brings together powerful suction, zero-tangle brushing, smarter carpet care, and wider edge coverage — all working together to keep your home cleaner with less to manage.
25,000 Pa HyperForce® Suction
Deep Cleaning in Just One Pass
Experience true cleaning power with 25,000 Pa HyperForce® suction. Whether on hard floors or carpets, it delivers strong pickup for everyday dust, crumbs, and embedded dirt.
18,500 18,500 18,500Pa
Max Digital Motor Power¹
Dual Anti-Tangle System
Hair In. Tangles Out.
DuoDivide™ Main Brush
Hair Tangling²
Hair Removal⁵
Anti-Tangle Side Brush
Thanks to its innovative arc-shaped asymmetric design, the Anti-Tangle Side Brush uses centrifugal force to guide hair toward the bristle tips, making cleanup quick and easy.
Hair Tangling²
See How the Dual Anti-Tangle System Works
Pick It Up
Gather It In
Strip It Off
The two main brushes feature a 10% speed difference, creating a differential effect that tears apart bundled hair in the central gap for easy removal.
Suck It In
Asymmetrical Spiral Arc
Soft Rubber Baffle
Longer Side Brush Bristles
Carpet Cleaning
No Drips. No Damp Tracks.
Auto Mop Removal
When Vacuum-Only
When Vacuum Carpet First
Advanced Carpet Cleaning Strategy
Corner Cleaning
Reverse the Spin. Cover More.
All-new Reversible Side Brush
Compare with Standard
Side Brush
Up to
30% more
corner coverage³
Mopping
Extends and Mops Like a Pro
FlexiArm™ Edge Mopping
1.85mm
Along the Edge⁷
Edge Coverage⁸
Duo Spinning Mops
15mm
Mopping Module Lifting⁹
200RPM
Maximum Rotating Speed¹⁰
1.85mm
Along the Edge⁷
Edge Coverage⁸
Duo Spinning Mops
15mm
200RPM
Multifunctional Dock
A New Look. A Cleaner Routine.
A Cleaner Mop, Every Time.
stain removal rate¹¹
Clean Starts at the Dock
High-Temperature Mop Self-Cleaning
Up to 75°C (167°F) high-temperature¹² mop washing. Helps reduce greasy buildup on mops for a more hygienic clean in kitchens and dining areas.
Warm Air Drying
45°C (113°F) warm air drying¹³ with 45dB low drying noise¹⁴. Helps reduce odors and keeps mops and the dock more hygienic between sessions.
Auto Tank Refilling
Refills for you, so mopping doesn’t dry out mid-run. No more dragging a dry mop across the floor.
See, Sense, and Steer Clear.
Roborock APP
The Brain Behind Every Clean
Roborock SmartPlan™ 3.0
After room types are selected, Roborock SmartPlan™ 3.0 learns your cleaning habits and automatically tailors the optimal cleaning strategy for each room, boosting suction where needed, rewashing the mop when necessary, and lowering power to reduce noise during Do-Not-Disturb periods.
Everyday Features
Tailored Vacuuming and Mopping Settings
Fine-tune suction power and water flow in the app for a more customized clean.
Temporary Cleaning & Skip Cleaning
Clean on demand or skip zones as needed — perfect for sudden spills or when you need quiet while focusing on work during cleaning.
Custom Routines
Come home to clean. Create personalized cleaning schedules so your robot automatically vacuums and mops before you arrive home — keeping your home spotless, right on time, every time.
Smart Suggestion of No-Go-Zones
Keep your robot out of trouble. Smart detection identifies tricky areas — like chair legs — and recommends No-Go Zones.
Target Area Re-Mop*
Re-mop the spots that need it every time. Mark stubborn areas in the app and the robot will automatically re-mop them during each cleaning run.
*The feature will be avilable through an upcoming OTA. Please stay tuned for the latest updates.
Matter Supported
Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home for seamless smart-home integration.
Your Privacy,
Our Top Priority.
Specs
352*350*96.6 mm
402*494*450 mm
2. Based on internal testing, the hair tangling rate is 0% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending or environmental conditions.
3. Based on internal testing by the manufacturer. Corner coverage is calculated within a 50 × 50 mm corner area based on the measured distance from the 45° corner point to the brush cleaning arc; uncovered area is defined by the two wall edges and the cleaning arc.
5. Based on internal testing, the hair removal rate 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively, across all five Vacuum Only Modes under controlled testing conditions. Actual performance may vary depending on environmental conditions.
9. Based on internal testing carried out by the manufacturer, the mopping modules can be lifted up to 15 mm. Actual results may vary depending on environmerhtal factors.
12. Based on internal testing conducted by the manufacturer. The stated 75°C refers to the temperature measured at the internal heater output, not the temperature of the mop itself. Actual performance may vary depending on environmental coonditions.
13. Based on internal testing carried out by the manufacturer the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
