Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
So Fresh. So Clean.
Meet Qrevo Edge 2 Flow — an ultra-slim roller mop robot vacuum featuring SpiraFlow™ 2.0 Pressurized Real-Time Self-Cleaning, 35,000 Pa HyperForce® digital motor power¹, tangle-free cleaning, and a brand-new all-in-one dock for effortless maintenance.
Sticky messes. Mixed floors. Handled.
SpiraFlow™ 2.0 Pressurized Self-Cleaning System
One Pass³. Truly Fresh.
  • Ketchup
  • Muddy Pet Stains
  • Soy Sauce Spills
  • Coffee Spills
Bacteria Removal Rate⁷
Specially designed to tackle sticky messes and spills, the upgraded SpiraFlow™ 2.0 uses a pressurized water pump to distribute clean water across the roller through 2× more hydration points⁴. Combined with 240 RPM rotation⁵ and 2.5× more of downward mopping pressure⁶, it delivers a fresher, more consistent clean with every pass.
16
240 RPM
High-Speed Rotation⁵
2.5x
Downward Mopping Pressure⁶
Explore the SpiraFlow 2.0 Pressurized Self-Cleaning System
Seamless Across Hard Floors and Carpets.
Built for Hard Floors. Barefoot Ready.
270 mm High-Density Antibacterial Roller⁸
Helps reduce water spots by
30%⁹
Suitable for everyday hard floors.
  • Wood floors
  • Tile
  • Marble
Precision water control, tuned to every floor.
Powered by AI RGB recognition, the robot intelligently identifies different floor types and automatically adjusts water flow for more effective mopping. On wood floors, it optimizes water usage to help reduce streaking.
*This function must be manually enabled in the Roborock app.
Keeps carpets dry.
Automatic Roller Shield
0 Drips
True Wet/Dry Separation¹⁰.
15 mm
Max Roller Mop Lift¹¹.
Incredibly slim. Surprisingly powerful.
8.98 cm Ultra-Slim Design
Built to clean deeper.
Success Rate
Cleaning in Spaces ≥8.98 cm High¹²
In Open Spaces
Under Furniture
Lifts Even the Finest Dust You Can’t See
35,000 Pa
Max Digital Motor Power¹
Hair Pick-up Rate on Floor¹³
15% increase
Pet hair pick-up rate¹⁴
Deeper into Corners. Closer to Edges.
The Reversible Side Brush sweeps debris out from corners, while the Edge-Adaptive Roller Mop extends to clean closer to edges, helping cover walls, furniture corners, and skirting boards with less effort.
30% increase
Corner Coverage¹⁵
Edge Sweeping¹⁶
<10 mm
Edge-Close Mopping¹⁷
Up to 44 mm
Extended Capability¹⁸
Zero Tangles. Effortless Upkeep.
No hair wrap. Made for pet homes.
Dual Anti-Tangle System
DuoDivide™ Main Brush
Hair Tangling Rate²
Dual Lifting Side Brushes
Hair Tangling Rate²
*The right side brush structure may vary slightly depending on the production batch.
The simpler, the better.
Easy-Rinse Dirty Water Tank
The redesigned dirty water tank features a simplified internal structure for easier rinsing, helping reduce residue buildup. An upgraded handle makes emptying more effortless.
75° Tiltable Roller
Tilts up to 75° for easier roller removal and deep cleaning.
Intelligent by Design. Private by Default.
280+ Types
of Recognizable Obstacles¹⁹
Spots the Mess. Cleans it Right.
Stain-Target AI Cleaning
The robot detects stain types through its RGB camera and automatically adapts its cleaning strategy, boosting suction for coffee powder and cat litter, or switching to mop-only mode for liquid spills.
For Wet Messes
For Dry Debris
For Wet Messes
For Dry Debris
Your Privacy, Our Priority
Fresh, from Start to Finish.
Multifunctional Dock
All-New Pressurized Self-Cleaning
The all-new system continuously jets clean water from the dock to refresh the roller, while dirty water is collected separately in the robot’s dirty water tank. With minimal water remaining in the cleaning tray, clean and dirty water stay separated—helping each mop wash stay cleaner, fresher, and more hygienic.
10%
Less water usage²⁰
Other Features
Intelligent Dirt Detection for Re-Washing & Re-Mopping
Dirt levels are continuously monitored during mop washing, with wash duration automatically adjusted and an extra mopping pass triggered for areas with heavier dirt buildup.
63°C Warm Air Drying
Dries the mops and dock base thoroughly with 63°C warm air²¹, helping prevent mold growth and unpleasant odors.
Auto-Refilling
Auto-Refilling
Automatically refills the robot's water tank with water when needed.
Provides up to 65 days²² without manual emptying.
Detachable Dock Base
Fully detachable dock base for easier washing when needed.
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry*. You're in control of every room, every rug, every time²³.
*These carpet cleaning settings must be manually enabled in the Roborock app.
Roborock SmartPlan™ 3.0
One Tap. Let Smart Take Over.
Roborock SmartPlan™ 3.0 automatically recognizes room types, learns your cleaning habits, and selects the optimal cleaning strategy—boosting suction when needed, rewashing the mop as required, and reducing power to minimize noise during Do-Not-Disturb periods.
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Pet Snaps
Track Your Pet
Track Your Pet
Video Call & Cruise
Video Call & Cruise
Pet Snaps
Pet Snaps
Track Your Pet
Track Your Pet
Video Call & Cruise
Video Call & Cruise
Everyday Features
Clean Beyond Curtains
Built-in Voice Assistant
Third-Party Control
Third-Party Control
Matter supported. Automate routines and control all your devices from a single platform. Also compatible with Alexa, Siri, and Google Home.
Key Specs
Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
Qrevo Edge 2 Flow
352*353*89.8 mm
402*470*451 mm
2. Based on internal testing, the hair tangling rate is 0% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively under controlled testing conditions. Actual performance may vary depending on environmental conditions.
3. Based on internal testing carried out by the manufacturer, the roller mop achieved up to a 100% removal rate of coffee spills, soy sauce, ketchup, and wet muddy spots in a single pass. Actual results may vary depending on environmental conditions.
4. Compared to SpiraFlow 1.0 with 8 hydration points. Based on internal manufacturer testing. Actual results may vary depending on environmental conditions.
5. Based on internal testing carried out by the manufacturer, when selecting the Extreme Water Flow setting in Custom Mode, the mop can spin at a maximum speed of 240 RPM. Actual results may vary depending on environmental factors.
6. Compared to the Roborock Qrevo Curv, which delivers up to 6 N of mopping pressure, the current model delivers up to 15 N, based on internal testing conducted by the manufacturer. Actual performance may vary depending on home environments.
7. Based on testing carried out by TÜV SÜD, over 99.99% of Escherichia coli, Staphylococcus aureus, and Candida albicans on the roller mop is effectively removed. Certification No. 704012602394-00. Actual results may vary according to the home environment.
8. Tested by SGS in accordance with GB 21551.2-2024 Antibacterial and Cleaning Function for Household Appliances, the antibacterial rate against Klebsiella pneumoniae ATCC4352 reached over 99.99% (Test Report No. ASH26-0017316-01A1). Actual results may vary depending on the home environment.
9. Compared to the performance of Qrevo Curv 2 Flow. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
12. The robot vacuum has a body height of 8.98 cm. Due to slight vertical flexibility in the front structural components, it may achieve limited passive compression when entering low-clearance spaces, allowing access down to 8.98 cm. However, scraping may occur. Actual performance may vary depending on environmental conditions.
13. Based on internal testing, the hair removal rate 100% when operating with 0.1 g of hair at lengths of 20 cm, 30 cm, and 40 cm respectively under controlled testing conditions. Actual performance may vary depending on environmental conditions.
14. Compared to the performance of Qrevo Curv. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
15. Compared to the corner coverage performance of Qrevo Curv 2 Flow. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
16. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
18. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer, the robot vacuum can detect and bypass objects as small as 3 cm wide and 3 cm tall. Recognition accuracy may vary depending on environmental factors.
20. Compared to the water usage of Qrevo Curv 2 Flow under Soaking Mode. Actual results may vary depending on environmental factors.
21. Based on internal testing carried out by the manufacturer, the internal heating module during drying can reach up to 63°C under standard room temperature conditions. Actual temperatures may vary due to environmental factors.
22. Based on internal testing carried out by the manufacturer. Actual emptying intervals will depend on usage habits and environmental factors.
23. This feature is applicable to household carpets with pile heights of 3 cm or below, covering the majority of carpets used in typical homes.
