VaporFlow™ 180°C ¹ High Temperature Steam Cleaning:
Softens Stains Before You Scrub
Melts wax and breaks down oil stains ⁴ with high temperature steam sprayed across a full cleaning width — No chemicals needed.
180°C
Consistent Steam ¹
2,200mg/min
High-Volume Steam ⁵
48°
Optimized Outlet Angle
As fast as 60s
Rapid Steam Activation ⁶
>99.9999%
Bacteria Removal Rate ⁷
≥ 99.9%
Allergen Removal Rate ⁸
Steam Cleaning Mode - Certified 0 Damage to Wooden Floors ⁹
Certified by TÜV SÜD: In steam-cleaning mode, the test simulated five years of cumulative use (18,000 strokes). The solid wood floor surface showed no swelling, no warping, and no cracking—delivering powerful cleaning with total floor safety.
Report No.: 704012500497-04
A Barefoot-Level Clean You Can Truly Feel
With 25,000 Pa suction, 33 N downward pressure, and 450 RPM brush rotation, it lifts embedded dust and tackles wet and dry messes for a deeper clean in a single stroke. ¹⁰
25,000 Pa
Suction Power ²
33N
Downward Cleaning Pressure ¹¹
32
Even Outlet Water Distribution
Precision water control.
The constant-pressure scraper minimizes watermarks ¹² with every pass, leaving a crisp, clean finish that dries in seconds.JawScrapers® Anti-Tangle Design
Conquer hair and debris with JawScrapers® design. Shark-tooth blades strip away tangles for an uninterrupted, flawless clean.
Tangle Rate ¹³
Up to 80 min
Battery Life on a Single Charge ³
Up to
660 sqm
Cleaning Area per Charge ¹⁴
1,000 ml Clean Water Tank
Holds enough water to clean your home, saving you from frequent maintenance tasks. ¹⁵
Dust tends to accumulate along walls and corners. Achieves <1mm ¹⁶ edge-to-edge cleaning, keeping every corner spotless.
<1mm ¹⁶
Edge-to-Edge Cleaning
180° Lie-Flat Design Cleans
Low Areas with Ease
180° Lie-Flat Design Cleans Low Areas with Ease
The body tilts smoothly to a full 180°, maintaining suction even when completely flat. At just 12.5 cm (4.9 in) high ¹⁷, it easily glides under furniture such as beds and sofas.
12.5 cm
Body Height
180°
Lay Flat
Blue Light Illumination
See the Mess You Used to Miss
Illuminates hidden dust and fine particles for a clearer view and more confident cleaning.
Agile Steering. Effortless Control.
70° Swivel Design
With a lowered tank and 70° swivel ¹⁸, it adapts to your home’s layout, making U-turns and edge-cleaning smoother than ever.
Balanced for Effortless Handling
By lowering the center of gravity for a grounded, stable feel, it delivers enhanced maneuverability that feels lighter in your hand and steadier on the floor.
During cleaning, the system auto-detects dirt levels and adjusts suction and water flow* accordingly. It deep-cleans tough spots and quickly refreshes lighter ones—saving time, effort, and repeat passes.
Track cleaning modes, steam preparation status, and live dirt detection* at a glance via the intuitive screen and responsive light bar.
Set it and forget it. With smart auto-dosing, one refill provides 30 days ¹⁹ of perfectly mixed cleaning solution.
* Available only in Auto and Sponge modes
* Available only in Auto, Eco and Sponge modes
Using steam and heat flow to deep-clean the roller with advanced solid-liquid-air separation technology, while the DirTect module senses dirt levels and automatically adjusts the cleaning power—keeping the roller fresh and spotless.
180°C
Steam Self-Washing ²⁰
95°C
High-Temperature Self-Washing ²¹
>99.9999% ²²
Flushes away leftover grime
Remove germs with steam
Adjusts cleaning intensity by dirt level
Spins out excess water
Loosens stubborn stains with steam and heat flow
Dries and fluffs the roller
Scrubs away heavy grime
Choose fast or quiet drying
* Please clean the dirty water tank promptly after each use.
Specs
Roborock F25 Steam
Roborock F25 Steam
265*246*1096 mm
316*353*1156 mm
1. Based on internal testing conducted by the manufacturer. The stated 180°C refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
3. Based on internal testing conducted by the manufacturer in ECO mode with a gentle suction setting. Actual performance may vary depending on environmental conditions.
4. Based on internal testing conducted by the manufacturer using common household stains such as butter, ketchup, mustard. Actual performance may vary depending on environmental conditions.
5. Based on internal testing conducted by the manufacturer, stable steam output at the nozzle is achieved after Steam Mode reaches a steady state.
6. Steam preparation is supported by a boiler heater rated up to 285W. Based on internal testing by the manufacturer. Actual steam preparation time varies with environmental conditions and the heater's starting temperature. Intervals may be shorter if the device has been recently operated.
7. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under steam mode, over 99.9999% of bacteria on the floor were effectively eliminated. Report No.: 704012501295-05. Actual performance may vary depending on environmental conditions.
8. Based on TÜV SÜD testing of pollen, cat dander, dog dander, and dust mite allergen under steam mode, over 99.9% of allergens on the floor were effectively removed. Report No.: 704012501295-05. Actual performance may vary depending on environmental conditions.
9. Based on TÜV SÜD testing, after operating the machine for 60 minutes and push and pull for 18,000 times on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012500497-04. Actual performance may vary depending on environmental conditions.
11. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
12. Based on internal testing conducted by the manufacturer, using the new roller brush on smooth tiles at 0.2 m/s. Minimal water residue was observed. Actual results may vary depending on water volume, floor type and home environment.
13. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet hair across all four operating modes under controlled testing conditions. Report No.: SHES250100116675. Actual performance may vary depending on environmental conditions.
14. Based on internal testing conducted by the manufacturer, operating the machine in Eco mode with minimum suction power at a speed of 0.55 m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
15. Estimated based on standard household conditions; actual performance may vary.
16. Based on internal testing conducted by the manufacturer. Edge cleaning performance applies to both the left and right sides. Actual results may vary depending on environmental conditions.
18. Based on internal testing conducted by the manufacturer. The 70° steering refers to the combined rotation of both brush heads, each rotating at least 35°. Actual performance may vary depending on environmental conditions.
19. Based on internal testing conducted by the manufacturer. A full cleaning solution tank provides up to 30 days of use, assuming once-daily cleaning in a controlled test environment. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
20. Based on internal testing conducted by the manufacturer. The stated 180°C refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
21. Based on internal testing by the manufacturer. The stated 95°C refers to the hot air temperature measured at the heater outlet, not at the steam outlet or of the water itself. Actual performance may vary depending on environmental conditions.
22. Based on TÜV SÜD testing against Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae, and Escherichia coli under self-cleaning mode, over 99.9999% of bacteria on the floor were effectively eliminated. Report No.: 704012501295-05. Actual performance may vary depending on environmental conditions.
23. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental conditions.
24. Based on internal testing conducted by the manufacturer. Actual results may vary depending on environmental conditions.
25. Based on internal testing conducted by the manufacturer. The moisture content of the roller brush after high-speed drying and silent drying was 0.68g and 0.24g. Actual results may vary depending on environmental conditions.
