Roborock F25 Ultra
Steam Gen 2
Steam to the Edge
Buy Now
This is a image of Roborock F25 Ultra Steam Gen 2
VaporFlow 2.0 Turbo Steam Cleaning
Tackles sticky stains with dense steam for a deeper, more hygienic clean.
WaveFlow: 90°C¹ Heat-Powered Cleaning
Helps lift oily residue with steady high-temp water flow.
0 mm² Triple-Edge Cleaning
Cleans closer along three edges while leaving less water behind.
Up to 100 min³ Runtime
Long-lasting power for uninterrupted room-to-room cleaning.
SlideTech 2.0 AI-Enhanced Glide Wheels
Push lighter, pull smoother, and clean with ease.
High-Temp Self-Cleaning & Drying
Keeps the roller fresher with less maintenance.
The Mess Stops Here.
VaporFlow 2.0
Steam, Unleashed.
A pull of the trigger activates Turbo Steam Mode from Steam Mode, releasing dense steam across the floor to soften, loosen, and lift stubborn messes and grease—without the need for chemicals.
5,000 mg/min
2.5× the steam volume of the previous-generation model.⁴
30 s
Less waiting, more cleaning.⁵
180°C
Stable steam for effective floor cleaning.⁶
500 cm²
More coverage for less back-and-forth.⁷
Powerful Steam. Thoughtful Care.
Powerful steam cleaning goes beyond visible messes, helping create a healthier home while staying gentle on floors. Certified by TÜV SÜD, it delivers hygienic cleaning and floor-safe care. In Steam Mode, solid wood flooring showed no swelling, warping, or cracking after a 5-year simulated use test (18,000 strokes).
Report No.: 704012500497-03
0 Damage
To Wooden Floors⁸
>99.9999%
Bacteria Removal Rate⁹
>99.9%
Allergen Reduction Rate¹⁰
WaveFlow
Grease, Broken Down.
For greasy kitchen floors, hot water makes the difference. Flowing evenly through the full roller, it helps cut through oil, keeps the brush from loading up with grime, and prevents dirty residue from ending up back on the floor. A triple anti-scale design helps preserve clean water flow, so hot-water cleaning keeps working the way you expect.
90°C
Running Hot Water¹
Cooking Oil Removal Rate¹¹
25,000 Pa
Wet & Dry Cleaning¹³
33 N
Downward Pressure¹⁴
450 RPM
Cleaning Strokes/min¹⁵
JawScrapers
Clean Without the After-Mess.
A cleaner finish starts with less left behind. Shark-tooth blades guide hair away from the roller, while a constant-pressure scraper helps reduce residual water and keep dust off the floor.
Tangle Rate¹⁶
Clean Close. Stay Gentle.
SensEdge AI Robotic Arm
Clean to the Edge. Drier in the Details.
Smart Lift. Less Mess Ahead.
The arm lifts as you push, helping prevent dirty water and debris from being pushed forward.
Stops Fast. Cleans to 0 mm².
It reacts in 0.18 s¹⁷ and drops into place, reaching 0 mm² along three edges for closer edge cleaning.
Pull Back. Leave Less Behind.
Adaptive Shock Absorption helps the arm glide steadily along the floor, wiping away residual water¹⁸ from floor seams for a cleaner, drier finish.
This is a image of Roborock F25 Ultra Steam Gen 2 This is a image of Roborock F25 Ultra Steam Gen 2
Built to Last, Gentle on Floors
Clean close with confidence. Certified by TÜV SÜD, solid wood flooring showed no swelling, warping, or cracking after a 5-year simulated use test (18,000 strokes) in Turbo Steam Mode with the Robotic Arm enabled.¹⁹
30,000 times
Threshold-Impact Tested for Lasting Durability²⁰
600 h
Stable Residual-Water Control on Smooth Floors.²¹
Confidence Across the Home
More Rooms, Fewer Stops.
Clean more of your home before you need to stop. An upgraded battery runtime gives you the freedom to cover larger spaces in one session, while large clean and dirty water tanks help reduce interruptions along the way—making whole-home cleaning easier from start to finish.
Up to 100 min
Long Runtime for Whole-Home Cleaning³
Up to 780 m²
Cleaning Area per Charge²²
Up to 30 min
Battery Life in Steam Mode²³
AI-Enhanced Glide, Effortless Control
With dual brushless motors driving each wheel and a low-mounted water tank that lowers the center of gravity, SlideTech 2.0 delivers responsive push-and-pull assistance—making the cleaner feel smoother, lighter, and easier to control.
70°²⁴ Swivel Design
Turns That Follow Your Flow
A 70°²⁴ swivel range brings smoother, more natural direction changes, making every turn feel fluid, balanced, and effortless.
FlatReach 2.0
Low Spaces, No Strain.
FlatReach 2.0 combines a 180° lie-flat design, a 12.5 cm (4.9 in) slim body²⁵, and remote-control capability to make low-space cleaning feel effortless. Reach deeper under beds, sofas, and cabinets with less bending, less stretching, and greater comfort and control.
Less Mess. Less Maintenance.
Cleans Up After the Clean
Steam and high-temp washing help refresh the roller after every clean. DirTect automatically adjusts water flow to match dirt levels*, while soak washing and active scrubbing help clear buildup—keeping the roller fresher with less effort.
95°C
High-Temperature Self-Washing²⁶
180°C
Steam Self-Washing²⁷
>99.9999%
Bacteria Removal Rate²⁸
*Available only in Auto Mode and Sponge Mode.
Dryer Inside. Quieter Outside.
After washing, 720° forward-and-reverse drying helps airflow reach more of the roller, reducing damp residue and helping prevent lingering odors before the next clean.
95°C
5-min Fast Drying²⁹
45 dB(A)³⁰
30-min Quiet Drying²⁹
Detachable Wet-and-Dry Separation Module
Separates solid debris from dirty water for cleaner, less messy disposal.
Auto Detergent Dispenser
Smart dosing helps boost cleaning performance.
Control with Intelligence
Blue Light Illumination
Dust Has Nowhere to Hide.
Blue light highlights fine dust, pet hair, and debris on the floor, making missed spots easier to see as you clean.
DirTect Smart Sensor
Mess Detected. Power Adjusted.
DirTect detects dirt levels in real time and automatically adjusts suction and water flow, giving tougher messes the cleaning power they need.
Smart Control, Made Simple.
Stay in the Know
Stay updated on mode status and steam preparation progress with a clear, intuitive display.
Set It in the App
Personalize cleaning settings, schedule self-cleaning and drying, and make daily cleaning fit more naturally into your routine.
Key Specs
Wet & Dry Vacuum Cleaner
265*250*1100 mm
Vacuum Cleaner with Dock
316*353*1165 mm
1. Based on internal testing conducted by the manufacturer, water is heated to the stated temperature under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual results may vary due to usage and environmental conditions.
3. Based on internal testing conducted by the manufacturer in AUTO mode with an ECO suction setting. Actual performance may vary depending on environmental conditions.
4. Based on internal testing conducted by the manufacturer. The 5,000 mg/min steam output refers to steam output measured at the nozzle after Turbo Steam Mode reaches a steady state. The 2.5× figure is calculated by comparing 5,000 mg/min with Roborock F25 Ultra’s stated steam output of 2,000 mg/min. Actual performance may vary depending on environmental and usage conditions.
5. Based on internal testing conducted by the manufacturer. Steam preparation is supported by a boiler heater rated at up to 285 W. The stated steam preparation time refers to a warm start after prior Steam Mode operation, measured after the device had been stopped for 3 minutes and then restarted in Steam Mode. Actual steam preparation time may vary depending on environmental conditions and the heater’s starting temperature.
6. Based on internal testing conducted by the manufacturer. The stated 180°C refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
7. Based on internal testing conducted by the manufacturer, steam coverage area was calculated by measuring the length and width of stabilized steam coverage in Turbo Steam Mode. Actual coverage may vary depending on environmental and usage conditions.
8. Based on TÜV SÜD testing, after operating the machine for 60 minutes and performing 18,000 push-and-pull strokes on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012500497-03. Actual performance may vary depending on environmental conditions.
9. Based on TÜV SÜD testing of Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae and Escherichia coli in Steam Mode, over 99.9999% of bacteria on the floor were effectively eliminated. Report No.: 704012501295-04. Actual performance may vary depending on environmental conditions.
10. Based on TÜV SÜD testing of pollen, cat dander, dog dander, and dust mite allergen in Steam Mode, over 99.9% of allergens on the floor were effectively removed. Report No.: 704012501295-04. Actual performance may vary depending on environmental conditions.
11. Based on TÜV SÜD testing of hot pot oil stains in Hot Water Mode, the tested stains were completely cleaned after one reciprocating operation, achieving a 100% cleaning rate for stubborn stains. Report No.: 704012500496-02. Actual performance may vary depending on environmental conditions.
12. Based on internal testing conducted by the manufacturer using mixed wet and dry debris and common household food messes, including milk and oatmeal, instant noodles, egg, ketchup, coffee stains, mustard, soy sauce, and other food-based stains and debris. Actual performance may vary depending on environmental and usage conditions.
13. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
14. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
15. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
16. Based on SGS testing, the hair tangling rate is 0% when operating with 2,000 strands of 50 cm dry and wet hair across all four operating modes under controlled test conditions. Report No.: SHES250100116675. Actual performance may vary depending on environmental conditions.
17. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
18. Based on internal testing conducted by the manufacturer, residual water in the cleaning area is reduced to near zero. Complete elimination is not implied. Actual results may vary depending on usage and environmental conditions.
19. Based on TÜV SÜD testing, after operating the machine for 60 minutes and performing 18,000 push-and-pull strokes on a solid wood floor, no blistering, bulging, or deformation occurred. Additionally, no visible scratches or color changes were detected. Report No.: 704012603246-00. Actual performance may vary depending on environmental conditions.
20. Based on internal testing conducted by the manufacturer. After 30,000 impact cycles and 30,000 threshold-crossing cycles conducted at a movement speed of 0.5 m/s, tested functions remained normal. Actual results may vary depending on environmental and usage conditions.
21. Based on internal testing conducted by the manufacturer. After 600 hours of back-and-forth push-pull operation on smooth floors at a movement speed of 0.5 m/s, all tested functions remained normal. Actual results may vary depending on environmental and usage conditions.
22. Based on internal testing conducted by the manufacturer, operating the machine in AUTO Mode with an ECO suction setting at a speed of 0.5 m/s. Actual results may vary depending on the home environment, level of cleanliness, cleaning habits, and other factors.
23. Based on internal testing conducted by the manufacturer in Steam Mode. Actual performance may vary depending on environmental conditions.
24. Based on internal testing conducted by the manufacturer, the 70° steering refers to the combined rotation of both brush heads, each rotating by at least 35°. Actual performance may vary depending on environmental conditions.
25. Based on internal testing conducted by the manufacturer. Actual performance may vary depending on environmental conditions.
26. Based on internal testing by the manufacturer, the stated 95°C refers to the hot air temperature measured within the air duct, not at the steam outlet or the water itself. Actual performance may vary depending on environmental conditions.
27. Based on internal testing conducted by the manufacturer, the stated 180°C refers to the steam temperature measured at the internal heater output, not at the steam outlet. Actual performance may vary depending on environmental conditions.
28. Based on TÜV SÜD testing against Staphylococcus aureus, Candida albicans, Klebsiella pneumoniae and Escherichia coli under Self-Cleaning (and Drying) Mode, over 99.9999% of bacteria on the floor were effectively eliminated. Report No.: 704012501295-04. Actual performance may vary depending on environmental conditions.
29. Based on internal testing conducted by the manufacturer, after one self-cleaning cycle followed by Fast Drying Mode and Quiet Drying Mode, the average amount of water remaining in the roller brush was 0.88 g and 0.55 g, respectively. Actual performance may vary depending on environmental conditions.
30. Based on internal testing conducted by the manufacturer in Quiet Drying Mode. Actual results may vary depending on environmental conditions.
