** The cyclone assembly of the Roborock H5 can be replaced with a dust bag. For detailed replacement instructions, please refer to the user manual.
1. Tested by TÜV Rheinland based on IEC 62885-4:2020/5.8 standards. Tested without accessories, in Max mode, and with testing an equipment diameter of 10mm. Actual results may vary depending on usage conditions.
2. Tested by TÜV Rheinland based on IEC 62885-4:2020/5.11 standards. Tested in Max mode for capturing particles of 0.3-10 microns. Actual results may vary depending on usage conditions.
3. Based on Roborock internal test with 2-in-1 Crevice Brush in Eco mode. Actual battery life may vary depending on usage conditions.
4. The Multi-surface Brush can only be used on carpets with a pile height of less than 2.5 cm (0.98 inches). Actual performance may vary depending on usage conditions.
5. Carpet Boost is only available on Standard mode. This function might not trigger on smooth mats or carpets with shorter piles. Actual results may vary depending on usage conditions.
6. Based on Roborock internal test in Standard mode. Actual power increase may vary depending on usage conditions.
7. Based on Roborock internal test in Standard mode. Motorized Mini Brush has a rotation speed of up to 2500rpm. With two nylon bristle strips on the brush, the Motorized Mini Brush is able to pat 5000 times per minute. Actual results may vary depending on usage conditions.
8. Based on Roborock internal test referencing GB/T4214.2-2020 standards. Sound level in Eco mode as low as 68.9dB(A). Actual results may vary depending on usage conditions.
Be the first to hear about exclusive offers, product news, campaigns and more.
