Hongkong
  • English
  • France
  • Germany
Roborock Qrevo Curv
Tangle-Free Cleaning, Effortless Elegance
Meet Roborock Qrevo Curv, blending elegance and innovation. The Dual Anti-Tangle System and AdaptiLift™ Chassis ensure exceptional performance by preventing hair tangles and adapting to various floor types for comprehensive, hassle-free cleaning. With 18,500 Pa HyperForce™ suction and FlexiArm™ Technology, every corner is spotless. Let Roborock Qrevo Curv bring warmth and unmatched performance to your home.
No Tangles, Just Clean Floors
No Tangles,
Just Clean Floors
Cleanliness
Without a Snag
Discover Roborock Qrevo Curv's revolutionary dual anti-tangle system with both main brush and side brush, perfect for handling long hair and pet-friendly homes. Enjoy tangle-free, hassle-free cleaning without constant brush maintenance.
DuoDivide™ Main Brush
The DuoDivide™ Brush features two parallel short bristle rollers with spiral blades that guide hairs towards the central dustbin inlet, where powerful suction swiftly removes it. The design prevents tangles and clogging, for effortless cleaning. SGS and TUV certified.
Hair Removal Rate1
100 %
Hair Tangling Rate2
0 %
FlexiArm™ Arc Side Brush
The unique arc-shaped asymmetric brush harnesses centrifugal force to prevent hair tangling, guiding it effortlessly to the bristle ends. SGS and TUV certified, this design ensures efficient and tangle-free cleaning.
Hair Tangling Rate3
0 %
Easy-to-Maintain Omni-Wheel
The upgraded omnidirectional wheel features a convenient brush next to the wheel that cleans it during use, making maintenance a breeze.
Elite Power, Better Than Ever
Elite Power,
Better Than Ever
Industry-Leading 18,500 Pa HyperForce™
Amp Up
Your Cleaning
Industry-leading 18,500 Pa HyperForce™ suction paired with DuoDivide™ bristle brush ensures that Roborock Qrevo Curv tackles tough cleaning challenges such as carpets and hard floor gaps, removing even the smallest particles.
HyperForce™ Suction4
18,500 Pa
Hair Removal Rate on Carpet5
99.5 %
18,500 Pa
99.5 %
Cover Every Inch
Roborock's exclusive FlexiArm™ Arc Side Brush and Edge Mopping System deliver exceptional cleaning coverage, eliminating blind spots and ensuring no dirt is left behind.
Edge and Corner Coverage6
100 %
Along the Edge and Corner6
0 mm
When detecting corners, the arc side brush quickly extends to sweep away messes for thorough cleaning.
FlexiArm™ Mop
The extendable right-side mop precisely cleans along edges and adjusts dynamically to corners.
FlexiArm™ Mop
Dual Spinning Mops
Leave Floors
Picture-Perfect
Achieve spotless floors effortlessly. Dual mops rotate with consistent pressure and humidity, effectively lifting and removing stains with ease.
Spinning Speed7
200 RPM
Water Flow Options
30 Levels
Reach New Heights
Reach New Heights
AdaptiLift™ Chassis
Uplift Your
Cleaning Standards
Elevate your cleaning with the industry-first8 AdaptiLift™ Chassis, featuring independently adjustable three-wheel control for versatile lift states. Elevate the entire chassis by 10mm9 or lift the front, rear, left, or right halves to adapt effortlessly to any home environment. The AdaptiLift™ Chassis ensures optimal cleaning coverage, easily navigating obstacles and different floor types.
Roborock Qrevo Curv effortlessly handles high thresholds by automatically lifting its omni-wheel. It can overcome standard thresholds up to an impressive 3cm10 and even navigate complex double-layer thresholds up to 4cm11, the highest in the industry12, ensuring uninterrupted movement across various surfaces.
Mid-to-Long-Pile Carpet Cleaning
Clean mid-to-long-pile carpets with ease thanks to the AdaptiLift™ Chassis, which elevates the chassis by 10mm, allowing strong suction power to penetrate deep into carpet fibers without clogging. Enjoy cleaner carpets and superior cleaning results with Roborock Qrevo Curv.
*The mid-to-long-pile carpet cleaning settings need to be activated manually in the Roborock app.
Liftable Brush and Mops
Tailored Solutions
for Every Task
For various cleaning needs, the brush and mops automatically lift to enhance effectiveness and prevent stains after cleaning.
Chassis & Mops Lifted
Mops Lifted
Brush Lifted
Brush & Mops Lifted
10 mm
Chassis Lifting
Chassis Lifting
10 mm
Mop Lifting13
Mop Lifting13
Mops Lifted
low-pile carpet
Mops & Chassis Lifted
Brush Lifted
Mops Lifted Mops & Chassis Lifted Brush Lifted
Vacuum-only
Mop-only
Carpet cleaning
low-pile carpet
Returning to dock
Mop drying
Where Elegance and Functionality Converge
Where Elegance and
Elegant Curved Aesthetics
Designed for the
Contemporary Home
Roborock Qrevo Curv's dock features a smooth, rounded form with graceful curves, exuding softness and sophistication. Enhancing your home's aesthetic appeal, it embodies Roborock’s dedication to creating a pristine environment.
167°F (75°C) Hot Water Mop Washing
Deep Clean,
Maximum Hygiene
Clean stubborn stains and greasy messes from mops without trouble using 167°F (75°C) hot water14, perfect for kitchens and dining areas. The hot water eliminates over 99.99% of bacteria from the mops, ensuring optimal hygiene. With three adjustable temperature settings, you’re prepared for any cleaning scenario.
Bacteria Removal Rate15
99.99 %
Intelligent Dirt Detection
Enhanced
Cleaning Excellence
Re-Wash
During mop washing, detection checks mop cleanliness, ensuring they are re-washed as needed for impeccable results.
Re-Mop
For areas with stubborn dirt and stains, the floors receive an additional mopping to guarantee a pristine finish.
*The automatic re-mopping feature needs to be activated manually in the Roborock app.
Re-Wash
Re-Mop
Zero-Touch Cleanliness
The incorporated self-driven cleaning module uses rotating scrapers and hot water to effortlessly clean the dock base, eliminating the need for manual maintenance.
Multifunctional Dock 3.0
Minimum Maintenance with
Maximum Convenience
Warm Air Drying
Auto Tank Refilling
Detachable Base
Warm Air Drying Dries the mops and dock base completely with 113°F (45°C) of warm air16, preventing the growth of mold and unpleasant odors.
Auto Dust Emptying Allows for up to 7 weeks without emptying.17
Intelligent Features that Set the Standard
that Set the
Standard
Say “Hello Rocky”
for Help
Say “Hello Rocky”for Help
Just say "Hello Rocky" to start cleanups, adjust settings for the perfect cleanup, or summon the robot where it's needed, all without lifting a finger. Enjoy convenient cleaning with voice control, even offline, without needing WiFi or your phone to control the robot.
Clean here
Clean the kitchen
Just vacuum
Start and Pause Cleaning
Cleanups
by Call
Specify Room Cleaning
Adjust Cleaning Modes
Auto Dust
Emptying
Mop Washing and Drying
Cleanups
by Call
Auto Dust
Emptying
*Intelligent voice assistant is available in selected languages, please refer to the Roborock app for more information.
Navigate Through
Any Space
Equipped with structured light and an RGB camera, the robot detects and avoids 62 object types across 20 categories18. It smoothly navigates around obstacles in both bright and dark environments, reducing the need for manual intervention.
Objects Recognizable
62 types
PreciSense™ LiDAR Navigation
Pet-Friendly
Because Your
Furry Friends
Deserve the Best
Quiet Cleaning
Fitted with brushless motors and an optimized hardware design, Roborock Qrevo Curv significantly reduces noise while cleaning. Mopping noise levels as low as 55dB19 ensure a remarkably quiet cleaning experience so your pets stay relaxed and unbothered.
Video Call
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Clean As You Wish
Roborock SmartPlan™
Technology
Tailored cleaning modes to your habits, room types, and floor materials, Roborock SmartPlan™ intelligently generates cleaning modes, and adjusts settings and preferences automatically. Enjoy worry-free cleaning with no need for manual mode adjustments.
Real-Time Cleaning
Progress Display
Experience enhanced cleaning management with the app's dynamic progress bar, easily tracking the robot's cleaning status. Save time with real-time updates directly on the homepage, ensuring maximum efficiency.
Temporary Cleaning
Always Within Reach
Third-Party Voice Control
Launcher Widgets
Apple Watch App
Matter Protocol
Embrace the Future
of Smart Living
Discover endless possibilities with Matter protocol and Roborock Qrevo Curv. Enjoy uncomplicated control of your robot vacuum and other smart home devices, without worrying about compatibility issues. Embrace the ease and joy of a seamlessly connected smart home.
Roborock Qrevo Curv with Refill and Drainage System
Take Hands-Free to
the Next Level
On top of the maintenance-free dock features of the Roborock Qrevo Curv, we've introduced a refill and drainage variant, taking hands-free cleaning even further.
Auto Water Refill and Drain
Check Your Environment
Strong Wi-Fi coverage
Installation Requirements
1. Maintain a space of approximately 32.2cm in height, 46cm in length, and 120cm in width.
5. The installation distance for the water refill and outlet pipes is recommended within 6 meters of the dock. If this is not possible, please contact customer service for consultation.
7. The pipeline layout should avoid passing through room doorways and corridors to prevent accidental breakage due to household traffic.
8. Ensure there are no thresholds, tracks, or steps higher than 2cm between the dock's installation site and the cleaning area to avoid the risk of entanglement or missed cleaning.
9. Before installation, disconnect the power supply of the dock. Turn off the main water supply switch, faucet switch, or angle valve switch in the house. Drain any remaining water from the pipes, connect the water lines, and ensure there are no leaks before powering on.
Auto Detergent Dispenser
Detergent Tank Size
600 ml
Compact Design
Save space with an impressive dock height of 32.1cm.
*Products with a Refill and Drainage system are only available in certain regions and countries.
  • Customizable App Features
  • Sensient™ Sensor Array
  • Adaptive Route Algorithms
  • Child Lock
  • Off-Peak Charging
Roborock Qrevo Curv
352*347*103 mm
450*450*450 mm
1. Certified No.PT/24/GEN/0244 by SGS. Actual results may vary according to the home environment.
2. Certified No.PT/24/GEN/0243 by SGS. Actual results may vary according to the home environment.
3. Certified No.PT/24/GEN/0245 by SGS. Actual results may vary according to the home environment.
8. Roborock was the first in the robot vacuum industry to mass-produce a product featuring a liftable chassis system with three-wheel control, officially launching this technology in Q3 2024.
9. Based on internal testing carried out by the manufacturer, the chassis can be lifted up to 10mm. Actual results may vary according to the home environment.
12. Based on research conducted by the manufacturer as of Sept 1, 2024, within the robot vacuum category.
13. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm.
14. Based on internal testing carried out by the manufacturer, the water at the clean water dispensers of the base can be heated up to 167°F (75°C) under standard room temperature. The actual temperature will vary due to environmental factors.
15. Based on testing carried out by TÜV Rheinland on Staphylococcus aureus and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the spinning mops are effectively removed. Test Report number:326033982a 001. Actual results may vary according to the home environment.
16. Based on internal testing carried out by the manufacturer, the air at the base's outlet during drying can be heated up to 113°F (45°C) under standard room temperature. The actual temperature may vary due to environmental factors.
